ISUZU RODEO 3.2L 1999 24V workshop manual
12 years 8 months before #39078 by manual-mecanica
ISUZU RODEO 3.2L 1999 24V MANUAL PUBLISHED BY MANUAL-MECANICA
I request Isuzu Rodeo Workshop Manual 1999 Motor 3.2L 24V, since they changed a gear of one of the camshafts and when lighting has no strength and throws codes P1340, P0300, P0463, also sounds as if it does not arrive
12 years 8 months before #39168 by manual-mecanica
Manual-Mecanica Response on the Isuzu Rodeo Manual Theme 3.2L 1999 24V
A Rodeo 3.2 L arrived with my workshop with that same problem and also changed a gear and the problem turned out to be a bad synchronization of the gears, the gears of this vehicle have a mechanism to tighten in another gear on both sides and thus avoid noises as a lack of lubrication, you can download the manual here on the site in the work handling area if you have not managed to let me know.
12 years 8 months before #39170 by manual-mecanica
A Rodeo 3.2 L arrived with my workshop with that same problem and also changed a gear and the problem turned out to be a bad synchronization of the gears, the gears of this vehicle have a mechanism to tighten in another gear on both sides and thus avoid noise as a lack of lubrication, I send you the manual
12 years 8 months before #39171 by manual-mecanica
12 years 8 months before #39193 by manual-mecanica
Thanks Spino, you can send me the manual to check the synchronized and I will notify you the result.
Greetings.
