I have to throw benzine to the carburetor
16 years 5 months before #6618 by manual-mecanica
I have to throw benzina to the carburetor published by Manual-Mecanica
I have a renault 11 hoods year 1985, my problem is that after a couple of hours I have to throw benzine to the carburetor so that the car split
16 years 5 months before #6622 by manual-mecanica
Manual-Mecanica Answer on the Re: I have to throw benzine to the carburetor
You may be a carburetor cleaning. Clear it completely and Czech that has a good fuel flow.
16 years 5 months before #6654 by manual-mecanica
Sorry, I think the problem is that the carburetor tank is backed up, this happens only if you have a loss in that sector, you will have to see a little gasoline in the sector, you have two gum in the Cuba if any is lazy loses the gasol From the floating very little to take more gasoline, if you give it too much, it would have to work. Salu2
