Escort injection pump 1.8d
16 years 5 months before #6677 by manual-mecanica
Escort injection pump 1.8d published by manual-mecanica
Hi: Cheer: I would need to know how to remove the stop valve that is in the injection pump: HUH: I hope that some charitable alam I throw a hand, OM facilitate the Escort Workshop Manual 1.8 D Year 96, thank you:)
16 years 5 months before #6681 by manual-mecanica
Manual-Mecanica Response on the Re: Escort 1,8d injection pump
It would be good to know if your Ford has antiaranque or not. If you do not have the electrovalve, it is easy to remove, it goes at the top on the side opposite to the piñon, tine a single cable that you can remove with facius, then the deender, you take out the plunger that almost certainly will remain inside, with a spring like ball, you move the new one, and ready. If you have to enter the thing, it changes quite a lot since you have to take out the anti -theft screw that you carry to reach the electrovalve, and this is already a fairly complicated task, if you doubt you do not mess.
16 years 5 months before #6698 by manual-mecanica
Thanks Jemaceiras, for your clarification. I see what you know what you are talking about, t specifying that it has at a sight, I imagine that it is the Carasa d steel qt taught in the photo, so I would dare to ask you a last question, how do you take this housing, can it be with this screw?
I would like to send you the photos like this !! My electronic email is: Can you send me your email address like this, I send you the photos?
16 years 5 months before #6702 by manual-mecanica
Hi Toni Copitas. My email is But I warn you if it carries Antiaranque Tunas Jaleo. Send me those photos to see.
