Hyundai Atos Manual
16 years 4 months before #6817 by manual-mecanica
Hyundai Atos Manual published by Manual-Mecanica
I would like to know if someone has the Hyundai Atos Workshop Manual since I need it to guide me how I can change a clutch of the Atos
16 years 4 months before #7106 by manual-mecanica
Manual-Mecanica Response on the Re: Hyundai Atos Manual
Hello, I want someone to help me
I have a 2001 Hyundai Atos and I mark Error 340 I think it is the position sensor of the Sigual Some can indicate how it is connected ...
It has three yellow and black blue cables
in addition to the injection system only acts the two injectors of the medium the other two are not activated by failure 340 or this has nothing to do with this other ..
or I will touch the computer ...
16 years 1 week before #8488 by manual-mecanica
I also need the manual, does anyone have it? How empty the radiator to change the liquid?
15 years 9 months before #9535 by manual-mecanica
Hello friends in the search for the Atos Manual, I download the L Hyundai Getz workshop manual that you will find on this page and I found that it has the same engine as the Atos in its 1.1 verction although it does not bring the part of the Manual Center Check it I hope it helps you help me a lot and if you find where it is the depth of the gearbox of the Atos
15 years 9 months before #9573 by manual-mecanica
GOOD MY FRIEND .. From Costa Rica I greet him. I tell you that the 2001 Atos Error Code is P0340 that indicates the following according to the autodata. Camshaft position sensor A.Bloque 1 defective circuit; And the probable causes are: wiring, camshaft position sensor or the engine control module, check it with patience since sometimes a false contact or with which the connectors are oxidized is sufficient for the can. Anyway, I look for the manual that I think I have seen it on some page. Any thing download the CD2 Self2 ;)
