Problem with Chrisler Stratus Dhoc 2.4 Year 1997
16 years 4 months before #7166 by manual-mecanica
Hello:
The car does not start the probma is purely electric since the benzine pump does not work and also does not reach current, the engine rotates but does not start, there is no spark in the spark plugs, that is, to the cirifier of coils and the benzine pump they have no corner.
If someone could give me a notion, they would be appreciated.
16 years 4 months before - 16 years 1 month before #7170 by manual-mecanica
Hello, it is very likely that you have some broken fuse or a relay in poor condition it seems to me that the one who gives energy to all the systems you mention is the ASR relay, turn on your light a thousand when putting contact with the ignition key? Basically, if any fuse is turned (usually the one that marks you as Ignition) you have no voltage anywhere, if you like I can send you the electrical diagram I send me a private message.
Latest edition: 16 years 1 month before by .
16 years 4 months before #7183 by manual-mecanica
These cars have the problem with the antiarranque, it must be canceled, go to an official dealership, with a module that will take it well, they will charge you € 30-40 normally, once started, they will put yours, but the remote control does not go, watch that there are not many workshops that have a modulus in good condition
16 years 1 month before #8099 by manual-mecanica
The Saturday I upload the Stratus Service Manual 1997 se, with 2.4 engine in Spanish so that you leave the problem, but in return that you upload some service manual, of any Veicture brand, so that the page continues to grow.
16 years 1 month before #8102 by manual-mecanica
Hello, I think you can have a problem with the Relay Asd Athdown since the symptoms indicate to it, it is located under the chest in the PDC "Power Distribution Center" and it is marked like this, check that the connections of this module and in specific that of this relay are good, and the other fuses with a tester Swuitch three times having happens.
greetings
