Lower the immokiller v1.10
15 years 5 months before #11335 by manual-mecanica
Manual-Mecanica Response on the Re: Lower Imaker V1.10
Desopilados wrote:
This program does not serve to desinmovilize, what it does is leave the compus of some cars, I have it and Jo is very helpful and you have to have an Eepron -Epron -Epron programmer - Epron
Hello, you can explain how to use it already lowers it and I have the epron programmer but I cannot work it I do not see that the memory is read or you have to activate another method thanks
The theme has been closed.
15 years 5 months before #11353 by manual-mecanica
You have to read the memory you have, for example, if you have a 95160 of Fiat, you read it and then keep it in a folders
. Denomination you select and just open the file, if the file does not correspond to you, and then press "Star" and ready
15 years 5 months before #11354 by manual-mecanica
Of course, you have it to record the file that generates you in the memeria that
the computer had, if you could be re -recorded, if you do not have a new one.
"Let me know how it went"
15 years 3 months before #12159 by manual-mecanica
Hello good.
Please you would be so kind to send me the code to use the program.
Thank you so much.
