- Thanks received: 1
06-19-2025 Hits: 824 Technology
Hello, I will tell you that I have the following problem: I need to know the position in the installation of the compression and oil rings. In other words, they are set, they have some brand.Jal wrote: Hello partner, try these pages, bookaller.net, Automecanico.com and Chevroletclub.com, you have to register but it is easy and free, I hope it helps you, a hug.
Hello: I will tell you what I need to know the position in the installation of the comprehensive and oil rings. In other words, they are set, they have some brand. It is an Izusu 2.3 Motor Motor Motor 4zd1 benkineJal wrote: Hello partner, try these pages, bookaller.net, Automecanico.com and Chevroletclub.com, you have to register but it is easy and free, I hope it helps you, a hug.
