I am looking for Toyota 4a Motor Manual
15 years 8 months before #9949 by manual-mecanica
I am looking for Toyota 4A Motor Manual published by Manual-Mecanica
Greetings mechanical colleagues, I am in a difficulty I am repairing a Toyota Corolla car of the year 90, automatic transmission, 4a-fe engine.
Find the failure of the problem of this vehicle (clear the engine) and found the surprise that the monoblok was diced in the part of the number 4 cylinder in the lower part does not damage the cylinder, but if I bend the rod seat and the crankshaft it is not worth it. The most curious thing was that this monoblok is not a 4A-fe if it is not 4th, that's why I look for the manual of this 4A engine waiting for your answer I say goodbye to me:
Josue GC
15 years 8 months before #9960 by manual-mecanica
Manual-Mecanica Answer on the Re: I am looking for Toyota 4A Motor Manual
Hi Josue, did you look for here in the manual section? If so and not this test in these pages, automecanico.com, clubdeltoyota.com and booktalle.net, you have to register but it is easy and free, I hope it helps you, a hug.
15 years 8 months before #9963 by manual-mecanica
According to I understand the monoblock is the same, you could look for another equal
15 years 8 months before #9984 by manual-mecanica
Thank you very much mechanical colleagues for all the help that this page provides, to the mechanics in the automotive area.
Now I find another problem, cleaning the crankshaft well, I realize that it has the following specifications 11 11 (in the weighs of the coach) and 5a.
As this crankshaft is discharged above (it is not worth).
I am looking for another crankshaft but now I don't know what a model buy 4a-fe, 4th or 5th.
The monoblock is a 4th and the vehicle should have a 4A-FE engine.
The big question is that crankshaft buy? And the metals in which Super will be?
I appreciate your answers before.
Atte:
Josue GC
15 years 8 months before #9989 by manual-mecanica
In general, the toyotas engines make them generic, but the best thing to do in your case, is to go to the consistent or the spare store with the sample and check that the one you have is the same as you buy, the other thing you can do is rectify the one you have and in doing so the Tornero will tell you the measurements of metals, the monoblock Motor than that of a 93 Tercel, and the outer structure is equal to that of the Tercel 97, now here in Chile the Tercel and Corolas are the same but with different decignations nothing more, maybe there is your case, the monkey block 2e is equal to 5e and 04e here in Chile at least, I think it only changes the race and camo of the cranks.
