Test with RPM
15 years 8 months before #10122 by manual-mecanica
Probma with the RPM published by Manual-Mecanica
Good day have all of you, I have a problem with my vehicle, a Nissan Altima 94 STD, when I turn it up quickly at about 3000 rpm and does not fall at 1000 rpm approx that you should maintain, what problem will you have, help of favor, thank you.
15 years 8 months before - 15 years 8 months before #10126 by manual-mecanica
Manual-Mecanica Response on the Re: Probema with RPM
Hello ... well ... First the first thing and that I advise you check the accelerator to start in case the cable or pedal have struck. Then check the minimal march control that is a valve located in the multiple of admission at the height of the acceleration butterfly. I send you an approx image of this valve hoping to be helpful
Last edition: 15 years 8 months before by . Reason: Image
15 years 8 months before #10135 by manual-mecanica
If none of this results, that is, the IAC or the pedal, which is as difficult but possible by the temperature sensor when it is cut or lengthens an alsa in the Czech and warning revolutions, since the Altima is a bit tangled to tabaja the signs.
15 years 8 months before #10148 by manual-mecanica
For the year of the car Creo, it manages the passing valve No IAC may possibly be bad or failing that the food of this is a handle that feeds the passage valve for the step for the idle starts for this before thinking about something else, you let us know greetings : Woohoo:
15 years 8 months before #10154 by manual-mecanica
Or even if you do not smoke at you at the above, put the ear and seek to see if the admission collector has some air input.
all the best
