DISTRIBUTION DRAW SUBARU LEGACY 2.2 ´91
15 years 8 months before #10124 by manual-mecanica
DISTRIBUTION DOTARU SUBARU LEGACY 2.2 ´91 Published by Manual-Mecanica
I would like to know which is the distribution draft of a Subaru Legacy 2.2 Automatic box ??
- If you start with the brands on the camshaft, or the differential brand ..
15 years 8 months before #10134 by manual-mecanica
Manual-Mecanica Response on the Re: Distribution Distribution Subaru Legacy 2.21
Hello friend in the sub -Uru that you possess is one of a belt or two, here in Chile there are double -leaf subarus, anyway you will have to ask for help since the camshaft fall, the pulleys of the cams The brands remain where I get usually put the crankshaft in position and the strap on the first, then I ppong the cams to move them more easily, then in a Bank compresses the hydraulic tensioner and you put it is not difficult but you will need another pair of hands so that the cams do not move.
