Lift Astra 1.8 glass
15 years 8 months before #10183 by manual-mecanica
Raise Astra 1.8 glass published by Manual-Mecanica
-: I am new and I have little practice in this, therefore, I have any fault-I have a chevrolet Astra 1.8-mod. 200000-MPFI-the engine of the lifting glass side driver and the zipper-ahora is revoked.
15 years 8 months before #10198 by manual-mecanica
Manual-Mecanica Response on the Retra 1.8
First, Bien bobenic to the Polenta forum, now I don't know what you mean with revive, but the fact is that it would not have to fail the tracero when repairing the striker, now what you have not told us is that it failed had the raising glass, and how the fault eats, tell us to be able to get conclutions, it would also be good that you told us if you have a central command or all move independently,
15 years 8 months before #10244 by manual-mecanica
Very friendly and I greet him cordially and I thank him for his attention-the front door was repaired- the back- always left side- the quoto engine was rewind- after this they did not work anymore --- right side they work well- Revised buttons are fine
has a buttone greeting
15 years 7 months before #10274 by manual-mecanica
When you have a button that commands all the glass, as is your case, there is the possibility of internal cuts of the Alzabidrios suiches, now if you smoke it is more likely that this happens, when blocking from the central region, you cannot act from the command of the same door, but this is solved by an automotive electric one, not nesestarily, a glass workshop. Yaris When the central command died, the glass are not operated from their commands corresponding to the doors, there is little that I can help you since it would have to disarm to see the problem, you would have to try to directly feed the rings the commands jumping the commands to verify that the problem is not of the electrical system of the independent doors, if they will repair the zip They were going to take some of the cables and this caused the fault, they would have to answer you, then it would be part of the guarantee, but as I told you an electric can check the proper functioning of Cencilla form
15 years 7 months before #10303 by manual-mecanica
First kita the tapestry on the bad side disconnects the electric motor connector and puts current (positive of the battery) to the terminal of the motorcito and earth (negative) to the other motorcit terminal if this good should raise the glass and the reverse should download if it works possibly it is the control plant that is bad internally or possibly wears separate fuses for each door as the Honda Civic takes them
