Fog Renault Megane Classicc Year 99
15 years 7 months before #10701 by manual-mecanica
Manual-Mecanica Response on the Re: Fog Renault Megane Classicc Year 99
You have to check the Damper or gates that are the ones that let the air pass either hot or cold. These gates are operated with some piolas that most likely are disconnected under the tabe of instruments.
15 years 7 months before #10712 by manual-mecanica
Juliocoche wrote:
Thank you, but in principle it does not enter water anywhere or the radiator loses.
Thank you
Hello again, July. If so, I think the water is inside the car and will not stop st de fipas until it dries. Think that the water or moisture caused by the condensation does not have to be under the carpet of the front seats, there could be water in the trunk and all the crystals of the car would be tarnished. Also, well below the floor carpet of the entire car that you will surely find the answer. Let's see...
15 years 2 months before #12554 by manual-mecanica
The recycled air circuit trap, surely disconnected, a junction card in the battery accommodation, when it is serrated, it does not enter sterior air and this makes the crystals tarnish.
