Check witness on Daewwo Nubira
15 years 6 months before #11070 by manual-mecanica
Manual-Mecanica Answer on the Re: Check witness lit on Daewwo Nubira
Hello friend first you can try resetting or releasing the battery waiting for a little while and connecting again if it does not leave it can be the Lambda probe located in the exhaust collector indicates the entrance of oxygen and anticontamination
15 years 6 months before #11077 by manual-mecanica
That failure you mention is very common in GM engines, initially the best thing to do is a sconer you will have the esactitus of which is the problem, now, this type of failure when the vehicle has no variation the most caused thing is that it is the oxygen sensor or the temperature sensor are the two most common options. The recipe of these cars can only be done with a scanner nothing more.
