I need support VW Jetta '87
15 years 7 months before #10697 by manual-mecanica
I need support VW Jetta '87 published by Manual-Mecanica
Someone to help me ........
Change the balls, joints, accessories, gear lever and now I do not find the 1st, all other changes are normal, before changing the accessories, the 1st had to look for it or entered with difficulty, it must have some secret .... For the regulation of the lever ... I hope comments .....: Blink: : Blink:
15 years 7 months before #10719 by manual-mecanica
Manual-Mecanica Answer on the Re: I need support VW Jetta '87
The best and the easiest way, for me, to regulate these rods is to look for the reverse in hand in the box to leave it and then put the lever in reverse and feeds test and now
15 years 7 months before #10725 by manual-mecanica
First of all disconnect the rods of the passeje selector, place the race of the first to second selector, from third to fourth, and reverse. Then change the onion, check that there is no game and subsequently change the bushings of the game of the voat, finally the main rod carries a screw on the tip so you can adjust and give less or greater race to synchronize the speeds well.
