Hi Foristas here, I have a problem with an Opel Corsa year 1995, a double camshaft engine, and 1.6 GLX engine, the injection system of this vehicle is a multitec S 95, multipunto, the command unit or ECU is 16213739, and the manufacturer's code is RQ, the problem is the following this vehicle From Heror -19-, a sign signal of RPM, tells me badly or missing, and that it is a memorized breakdown, the problem is the following this engine that is x 16 xe, it has a camshall and another of follow, if any of them were in poor condition there would be no spark and the engine would not start, change the sensor of the camshaft and the engine starts and the engine starts and it goes well but it goes well but it goes well but it goes well Check and with the same code, if someone had something similar with a Corsa or another vehicle please answer to get an idea of the detail since I do not have a computer from the same vehicle by hand to project, thank you.
