Opel Corsa, 1995
15 years 6 months before #10957 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Corsa theme, 1995
Friendly ones I am still being the subject of the Corsa, I have not reached a verdict yet but I do not think they are far from the truth, of course something happens half a comic with the vehicle, this part and lifts well, but at the time of walking, it does not have it, the compression is ok Something that accompanies him, I will change it anyway. Safe and tell you how it was.
15 years 6 months before #10999 by manual-mecanica
Friends I tell you, change the camshate sensor, and the light continues to light, but it takes a little more, now the problem of engine power was a separate problem there were two spark plug cables that the spark jumps to any side and aveses jumps well so that it changes cables and spark plugs and everything is well Check, and tells me a sign of RPM captor, well now you notice the speed sensor, the vehicle does not mark me, it could be that the signal is being confused with the vehicle speed sensor, because it does not mark but the code does not leave me.
15 years 6 months before #11002 by manual-mecanica
Hi Kikemec,
the RPM captor failure refers to the crankshaft sensor, not the camshaft sensor. Try another sensor and the check is going to compose. I don't think the computer is confusing the RPM signal with the speed. At least with a parked car and ignition, there is no remote possibility. Greetings, ¨jueja.
15 years 6 months before #11016 by manual-mecanica
Check the sensors' codes if the one you change is the same, the GM switchboards change the other, they usually do the auto reset and if they do not read any anomaly, they turn off the light, then remember that the switchboard reads the advance that the engine needs through the position of the trees and this sensor is the one that reads them, also checks the MAF Flow sensor can have something, but first of all, it can From the sensor, also check the fuel pressure that the car has, greetings.-
15 years 6 months before #11032 by manual-mecanica
Friends change the crankshaft sensor and the light still comes on, but notice that when it turns it on, it is when I pass through a high This is the failure, unfortunately the owner no longer wants to spend more money, so I will not be able to get the crankshaft to repair it, the problem is that I will keep the doubt and I don't like that.
