Forums
15 years 6 months before #10933 by manual-mecanica
Forums published by Manual-Mecanica
I have the next problem with my car a Nissan FB14 GA15 engine. Diagnosis was that the MAF is bad to which the entire shutter changes after having rebuilt the harnes and terminals, always continues with the same failure, my question is if I have to go to program it
15 years 6 months before #10955 by manual-mecanica
Manual-Mecanica Response on the Re: Forums
Not the MAF is not programmed, you want the problem is another or the MAF is not adequate, or you want to have the fault stored in the ECU and you have not erased it
15 years 5 months before #11314 by manual-mecanica
I need help with Nissan V16 1998twuin Cam became a semi -justee and humans blue over the 80kms but they have not always told me of a valve in the admission I would like to know which thank you very much Atte.
15 years 5 months before #11331 by manual-mecanica
I mean to saver that valve you have to take out the butt and check, you can't know how much nothing more, you really have to take out the spark plugs and check your tips according to the color they take you can determine what cylinder you have the problem, now to change a valve you have to take out the cylinder head, or it may not be the valve and it is a guide or retain from the same way. Take out the spark plugs and tell us as they came out.
