About Chevrolet Spark 2008
15 years 6 months before #11065 by manual-mecanica
About Chevrolet Spark 2008 published by Manual-Mecanica
Someone has the Chevrolet Spark workshop manual. or know how your valve system is, if you have regulation or are hydraulic
15 years 6 months before #11075 by manual-mecanica
Manual-Mecanica Answer on the Re: About Chevrolet Spark 2008
The spark has hydraulic takis do not have manual regulation, unless it has a small regulator in the upper part of each taki, if this is the case you will have to release the banks of the lift part to regulate it is complicated if, generally they are made of factory taraders.
