DAEWOO LANOS 2000 1.5 Baja failure
15 years 5 months before #11364 by manual-mecanica
Manual-Mecanica Response on the Re: Daewoo Lanos 2000 1.5 Low failure
I tilted with an electric corduroy so you tell something you have walk the vehicle and turn on everything you can turn on, step on the brake to act these lights too and see if the release is unstable or the vehicle stops, if this happens you have land problems to the kia happens Check and warn them?
15 years 5 months before #11402 by manual-mecanica
I already repaired gentlemen, I had to buy another coil since the one I had was of poor quality (the spark was very weak) only lasted 6 months.
Thank you very much for the suggestions ........: Laugh:
