Terrano motor arrangement at home
15 years 5 months before #11405 by manual-mecanica
Manual-Mecanica response on the Re: Terrano motor arrangement at home
Greetings friend Oliver Here you have the manual rapidshare.com/files/112340662/manual_co...o_nissan_terrano.rar now defend yourself as you can and good luck you will need .... With respect to separate the engine from the box I tell you to call a friend and the pienza that you should see if the clutch bearing has a bray ring that will have a fastener ring that, when you have released everything. Now I advise you to take it out with everything when I put it again it will be easier for you if you do not have the experience. Luck again and tell us how reparation is going.
15 years 5 months before #11413 by manual-mecanica
Thanks Uncle! I will follow your advice and have if it does not rain or do something hehehehe, with luck or without it I am having a good time of the car :) I do not walk cd it will give it X satisfied
I tell you how it is going, a greeting !!!!
