Izusu Rodeo Problem 2000 4v
15 years 5 months before #11408 by manual-mecanica
Izusu Rodeo Problem 2000 4v published by Manual-Mecanica
Good, I have an Izusu Rodel year 2000 engine 2,200 cc. The car starts well, but cold is like in three pistons and stuffs gasoline candles. Already when the car heats the motor matches and stops failing. Several scanning has already been made and it only comes out as "hitting in cylinder 4".
He sent to check the computer and is well, although the light of "Checking Enginen" is still on.
4 months ago the car was canceled.
Then I would appreciate that they help me, if they know that the problem that I tell you is derived ...
thanks
15 years 4 months before #11587 by manual-mecanica
Manual-Mecanica Response on the Re: Izusu Rodeo Problem 2000 4V
I have to help but I need you to send me the code s) that the scanter registers
