Help with Cherokee
15 years 5 months before #11439 by manual-mecanica
Help with Cherokee published by Manual-Mecanica
Companions I have a geep does not start the coil, the distrin is little or faint spark
15 years 5 months before #11483 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with Cherokee
Greetings friend, there are very few data to give you a more exco diagnosis, but it might be that the coil was missing, if you do not have how to change it, this, deconent the cable that reaches the distribution from the coil and sapoalo only a little, you have that the spark jumps the lid this increases the strength of the spark, if you get it to turn it on. Remember that if you have tried a lot, it is possible that the engine is saturated with gasoline, it is better to remove the spark plugs and clean them and turn the engine without it just a little. Another, if changing the distributor, make sure that it is in the weather and Acute yourself to fear the battery well charged this helps the spark already rotate the engine faster. Good luck and I hope you tell me how things are going ...
