Any problem with a vehicle?
15 years 5 months before - 15 years 5 months before #11443 by manual-mecanica
Any problem with a vehicle? Posted by manual-mecanica
That such greetings to all the members of this magnificent website, I would like to do so that those who need some information or help must be more specific, in the way of requesting the help, in how the problem happened, and that they have done if they have extracted the fault codes for possible solution
Being your orders I can help them in what is needed some important data first of all will be the following:
Sub-marca PAIS brand
Year type of injection
ENGINE
TRANSMISSION T/M O T/A
If you have air conditioning
If it is 4x4
Failure symptom
What have they done
DTC found
EXAMPLE:
Chevrolet Chevy Mexico 1999
1.6 LTS TBI T/M WITH A/C
SYMPTOM: MINIMUM ERRICA AND DROWNING MARCH, BUJIAS When they withdraw them, they have Ollin
There is no DTC
In this way it will be easier to help colleagues I hope and this can serve you being at your service
Since I have observed that many users do not know how to consider their problems to help them
Last edition: 15 years 5 months before by .
The theme has been closed.
15 years 5 months before #11447 by manual-mecanica
Manual-Mecanica response on the Re: Tines any problem with a vehicle?
Someone can help me I have a 93 Full Vocho has a problem that does not load the battery already changed the coil did the scanner and came out that he had a voltage problem nothing more
15 years 5 months before #11448 by manual-mecanica
First of all, I need you to talk to me what the electric or mechanic said, and because you say it has a voltage problem, I need you to be more specific to what you say to see how to help you and if they occupied the scanner which are the fault codes thank you
15 years 5 months before #11449 by manual-mecanica
First of all, I need you to talk to me what the electric or mechanic said, and because you say it has a voltage problem, I need you to be more specific with what you say to see how to help you and if they occupied the scanner which are the fault codes thanks, and why they changed the coil since it has nothing to do with the voltage problem
15 years 5 months before #11460 by manual-mecanica
You find me how to manually erase the chivato of failure of a 960 volv
