Toledo 1.9 Alternator Correa
15 years 5 months before #11445 by manual-mecanica
Toledo 1.9 Alternator Correa Published by Manual-Mecanica
Hello,
I was left with my father's Toledo and has a lot of trot.
I would like to know if someone could tell me how I can do to change the run of the alternator who has broken me in a bad way I have disassembled but I don't get well what the tensioners are, someone could tell me a bit ???
15 years 5 months before #11450 by manual-mecanica
Manual-Mecanica Answer on the Re: Toledo 1.9 Alternator Correa
Good evening ,,, the alternator's strap is tense with the same alternator, it is easy to change it, the alternator has about three screws that are screwed to the chassis, you just have to loosen a little and one of them is the one that tense the belt, once it is well placed, you just have to press the screws again, eye, if you feel the coorrrhea of ​​the alternator of the alternator. bistazo a ve
15 years 5 months before #11459 by manual-mecanica
If you have a tensioner, it is the roller that looks above than the others. It has no complication, just remove it from the screws to which the engine is taken.
