Hysoung Aquila GV-250 motorcycle problems
15 years 5 months before - 15 years 5 months before #11510 by manual-mecanica
Moto problems Hysoung Aquila GV-250 posted by Manual-Mecanica
Good night;
I beg you to help me with a problem that I have with this motorcycle.
My problem is as follows:
Wash the carburetor, change the needles of the floats with their respective bases, mount the carburetors, I pledged the motorcycle and went out to do it to see how it had stayed, and when I made the first stop. I went out, so I thought it was surely cold, but I kept the test aher and at each stop I went out. I returned to the workshop again and verify that by the defogues where the collectors of the floats bounted gasoline ... the carburetors disassembled the carburetors and recalibrated the floaters and armed again, sli to do the test again, to which the parking lot, begins to throw gasoline ...
the question I have is:
if I emphasize the floats to close the needles.
They could collaborate.
You can send me the answers you have ..
carefully;
Luis Ching
PD passing I could ask for the favor if someone has the catalogs of this motorcycle. And especially for carburetors repair ...
Last edition: 15 years 5 months before by .
15 years 5 months before #11535 by manual-mecanica
What happens to you is that the level of the float as well as the needle are bamered, that is why the carburetor revalates you, you will have to disassemble and check these converters there is no more failure than this.
