Peugeot 307 SW antipolution system failure
15 years 5 months before #11550 by manual-mecanica
Peugeot 307 SW antipolution system published by Manual-Mecanica
Very good morning,
I have a problem with my Peugeot 307 SW, a few days ago the "anti -patent system" failure alarm went on.
As I have read in other cases when this happens the car does not exceed 2500 laps, but in mine it does not seem to have lost power and if it passes 3000 laps.
I put about 4000 for 20 minutes to see if the warning was removed, without noticing anything anomalous in it, but not for those.
Does anyone have an idea that it may be happening?
Many taxes for your help.
15 years 4 months before #11561 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 307 SW Antipolution System failure
Caballoco It is best to make a Scaner like this you do not change feet to change them, that notice informs you of a problem in the injection system or any of its components that are not few, I just repaired one with a fujitive current in a cylinder, on Monday repair another for the oxygen sensor, and the notice is the same.
15 years 4 months before #11592 by manual-mecanica
I have already touched another for the Turbo Geometry Position Sensor.
15 years 2 months before #12767 by manual-mecanica
Hello everyone, I have another 307 SW 1.6 and it gives me the pollution notice since the first year, it has repeatedly taken to the workshop does not give me a solution or with the machine. The truth is that it is quite bad, change of bulbs every month, at 100,000 km clutch and radiator change. Taking into account that the kilometers performed have been done on highway at speeds and normal driving. When the radiator was ambiated, they put one more thin, since apparently the house had changed them for giving problems the previous ones. And to top it up now a noise has come out in the distribution. Thank you
