Hello, my shoe made blue smoke
15 years 4 months before #11715 by manual-mecanica
Hello, my shoe made blue smoke published by Manual-Mecanica
How, as soon as I knew this very good
Renault 5 1978 STD portal. 4 cyl.
The problem of my car is:
Hecaha smoke blue. The mechanic taught the oil change and put a high to the smoke they sell in the ref. California and it doesn't work the same, and I
charge
my
15 years 4 months before #11720 by manual-mecanica
Manual-Mecanica Answer on the Re: Hello, my shoe made blue smoke
Hello, if your shoe is from the year 78 and it still works is very likely that the blue smoke is because the oil is going to the combustion cameras, for the above you should change adds in the pistons, with that it should happen.
15 years 4 months before #11901 by manual-mecanica
The Renault 5 has a serious rings problem is the corduroy of all these machines and smoke as a disco machine, to make a rings change you need many adeas to change the floating shirts and veir rings of the valve is a complete adjustment actually and I will give you for about 10 more years, if you want to do it you do not disassemble nothing until you ask us, if you have not worked in mechanics. For this you must disassemble the shrimp of the gear selector, well tell us and luck.
15 years 2 months before #12722 by manual-mecanica
Put an additive (a maximum compression with a 20W50 oil and fix if the problem follows the rings
