Disadvantes TWINGGO IGNITION
15 years 4 months before #11825 by manual-mecanica
Disadvantes Twingo ignition key published by Manual-Mecanica
Gentlemen, good morning.
I have a concern referring to the Twingo ignition key, it presents continuous inconveniences with the ignition alert.
Request the key through the concessionaire and have tried twice that the vehicle recognizes it is not successful the operation.
If you know a little more about the problem and you can help me.: Laugh:
15 years 4 months before #11853 by manual-mecanica
Manual-Mecanica Response on the topic Re: Disadvantes TWINGGO IN
Your problem is not the look if not the unit that recognizes the key that goes around the ignition cylinder that proves another
15 years 4 months before #11943 by manual-mecanica
I think the same since the coding is established by factory, and it does not work is not a key to the reader.
