Problem with the warmthriers
15 years 4 months before #11874 by manual-mecanica
Problem with the warmthriers published by Manual-Mecanica
Hello colleagues, the problem I have is as follows:
I have a Seat Ibiza 1.4 TDI of the year 2006, and suddenly the warmthriers of the heater in the main picture is intermittently, I would know someone to tell me what it may be due ?, Thank you for your collaboration.
PS: If someone reads this message, please answer me as soon as possible.
Receive a cordial greeting.
Fernando
15 years 4 months before #11882 by manual-mecanica
Manual-Mecanica response on the Re: Problem with the warmer witness
Hello,
the safest thing has melted a brake light. Check them
15 years 4 months before #11884 by manual-mecanica
Hello, I am new in the forum and I would first like to give greeting.
The one of your Ibiza may have a false contact or that the UCE is in conflict with some device of the electrical part, some vehicles give you information on the screen, usala, use the logic looking for the breakdown, check the battery and alternator load, these sometimes do not get into good condition and give many problems. It also checks all masses (-) since a loose or lazy mass are intermittent faults, check everything you can even the lueces. all the best
15 years 4 months before #11896 by manual-mecanica
The first thing you have to look is if the brake lights work when you step on the pedal with the contact on if any or the third brake light does not work you have the breakdown in the button that carries on the brake pedal. It is very easy to change but buy it originally the pirates fail more a greeting.
