Skoda Fabia Address Problem
15 years 4 months before #11971 by manual-mecanica
SKODA FABIA ADDRESS PROBLEM PUBLISHED BY MANUAL-MECANICA
Hello,
I bought a Fabia de Gasoil secondly. The problem is that from time to time the management pilot comes on and the steering wheel gets hard for a few seconds. Some days spend several times and others none. Does anyone know what can be happening? Will I pass out when I go to Tayer? All the best.
15 years 3 months before #11993 by manual-mecanica
Manual-Mecanica Response on the Re: Skoda Fabia Directorate Problem
Have you checked the direction fluid? I think the first thing would be to buy the level. The deposit differs because it has a relief steering wheel. If the level is low by filling it with the direction oil that the car should carry (green color) that in any spare parts house there is for 10 euros approx. If you are missing and fill it at the end of the day, check the level in the same place. If not, you have to look for a escape. If you have a leak in the steering zipper, you have a problem. I hope I can help you. Greetings and good luck.
15 years 3 months before #11995 by manual-mecanica
Give me the car bin to see if I can also help possible engine type
15 years 3 months before #12002 by manual-mecanica
What is bin?
15 years 3 months before #12003 by manual-mecanica
Thank you very much for your help
to see if this afternoon I talk to someone who can look at what you tell me. I really have no idea of ​​cars and I would surely put the leg. Today the management pilot only ignited as long as I did not start, although the address continues to be hard for moments. Let's see if it is not a leak ... I have it only for a month (second hand) and I hope that I have not been wrong with the purchase .... a greeting. Thanks again.
