Nissan 200sx Year 1987
15 years 5 months before #11976 by manual-mecanica
Nissan 200SX year 1987 published by Manual-Mecanica
Hello, I need help with my Nissan 200SX, with the electrical system since it does not want to give me Star, at first I did not want to start because the gas pump did not work and now it is the start.
If someone can help me, I would appreciate it.
THANK YOU
15 years 5 months before #12030 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan 200SX year 1987
I do not understand you well, but you say that when you give the key to being the car does nothing?, if this is the case to give direct start without the key, to see what happens, if it is coded use the reserve key and see that it suspends notans to be able to guide you, because if you do nothing, nothing can be start or a terminal in poor condition.
15 years 4 months before #12299 by manual-mecanica
Thanks for the aid, the car da start and the problem of the gasoline pump was that it did not happen current and we solved it.
Thank you.
