A3 gearbox problem
15 years 3 months before #12278 by manual-mecanica
Manual-Mecanica Response on the Re: problem box problem A3
Thank you very much for your advice. I've already bought it, but this ok. I have gone through a workshop to make a look and he has told me that the problem that the marches are attached to me is due to the Bimasa steering wheel since the clutch is already quite spent. I have made a budget for the clutch kit change icing+clutch of 800 euros mounted and ready. Is it a good price?
15 years 3 months before #12347 by manual-mecanica
It is not a bad price work in an official service and I tell you that they are not passed, only a bima bollant can cost you up to 500 or 600E so it does not seem scarce.
15 years 3 months before #12360 by manual-mecanica
hello. The mechanic has changed the clutch just because it has told me that the Bimasa steering wheel is fine. He has told me that the tremor that produces me of the injection pump that is wrong, because he works late. The car after walking a little with him turns off and when you're going to turn it on, it takes a long time. Will the injection pump now? Greetings and thank you very much.
15 years 3 months before #12428 by manual-mecanica
I do not understand the problem that the marches are no longer solved because what you say now has nothing to do with
15 years 3 months before #12435 by manual-mecanica
If the problem of the marches is already solved. The clutch was too deteriorated and did not let the gearbox work well.
