Fiat Fiorino 95
15 years 3 months before #12141 by manual-mecanica
Fiat Fiorino 95 published by Manual-Mecanica
Together with greeting them nesecito if you can help me I have a fiat fiorino year 95 the problem schens is spending a lot of benzina suede thanks :(
15 years 3 months before #12172 by manual-mecanica
Manual-Mecanica Response on the Re: Fiat Fiorino 95
First, it makes a simple adjustment a basic refinement, change of filters and spark plugs, if it does not improve you can have two problems or temperature sensor or temperature sensor as long as you have starting problems in the mornings.
15 years 3 months before #12181 by manual-mecanica
Friend thank you very much was the oxygen sensor had a cut cable
