Tahoe 99 5.7l check Engine
15 years 3 months before #12156 by manual-mecanica
Tahoe 99 5.7L Check Engine published by Manual-Mecanica
Hello everyone, my problem is that my tahoe does not turn on the focus Engine (if you give me fault codes) or when you give the key they tell me that it is melted but I do not know how to start disassembly the board would appreciate your help
Edgar C
15 years 3 months before #12157 by manual-mecanica
Manual-Mecanica Answer on the Re: Tahoe 99 5.7l Check Engine
What car is it? =
15 years 3 months before #12170 by manual-mecanica
It is a Chevrolet truck brings the 350 5.7L 8 cylinders engine is very good but I need the repair manual
14 years 6 months before #18033 by manual-mecanica
12 years 6 months before #39530 by manual-mecanica
Manual-Mecanica Answer on the topic Tahoe 99 5.7l Check Engine
You just have to remove the upper molding that surrounds the steering wheel, control of lights, stereo, air conditioning, pulling it, only staples, and you can remove the board with a dice of 8 or 7 ml ...
