Mini 2003 Code P1627
15 years 3 months before #12323 by manual-mecanica
Mini 2003 P1627 Code published by Manual-Mecanica
I have this P1627 code (high entry load sensor) in a 2003 mini, I already changed the alternator and I continue with the same code, has anyone already happened to him something similar? Greetings
15 years 3 months before #12356 by manual-mecanica
Manual-Mecanica Response on the Re: Mini 2003 Code P1627
I would recommend you review the lines since the code refers to a computer control line
15 years 3 months before #12361 by manual-mecanica
Thanks I have already reviewed all the lines, they are only four cables and everyone is perfect
15 years 3 months before #12418 by manual-mecanica
Ok. I refer to that code is fault in the computer control lines that the fault can be the computer since the code is P1627 and it is described in this way
P = motor -related code
1 = manufacturer's thick code
6 = computer control outputs
Any questions you write to me ami mail
