1.5D Micra does not go out !!!!
15 years 3 months before #12378 by manual-mecanica
Manual-Mecanica Response on the Re: 1.5D Micra does not go out !!!!
Normally they are not very expensive, it is round with a cable at the top there are times that this little hill is covered with a rubber cap so that the terminal does not deteriorate.
15 years 3 months before #12379 by manual-mecanica
Thank you so much.
I will see if I find it, and as soon as I see it I tell you if I see something.
Thanks again.
15 years 3 months before #12411 by manual-mecanica
It has happened to me once it was the mass cable of the battery that did not make contact in chassis, check the cable well and the route sometimes sulfates or loosen up, then that valve if you are going to disassemble it attention to the pin can fall, check if it comes out with aluminum remains that if so it is the pump that is defective and is losing metal, but I do not know that amount of km you have traveled but first of all, you have traveled but first I said, if you have an auxiliary cable you can put it from the battery to the engine and tests, be sure that it does the contact and Puebas if everything goes ok Eureka, if you do not try to turn off the car and if you do not turn off you use the ground cable as I said tests first directly to the engine and if you do not turn off you connect it to the body, remember the negative cable of the battery. greetings
