Mitsubishi Montero Problem Lights Table
15 years 3 months before #12405 by manual-mecanica
Mitsubishi Montero Problem Lights Published by Manual-Mecanica
Hello everyone I have a mitsubishi Montero 3.2 Did of the year 2000. The problem it has is that when I start it, the battery light, that of the water detector in the gas-oil filter and the oil in yellow and no one is turned on. I have checked the battery and load load 15.40v. Some of you have been given a problem similar to this? Haber if you can help me
15 years 3 months before #12407 by manual-mecanica
Manual-Mecanica Answer on the Re: Mitsubishi Montero Problem Lights Table
Hello 15.4 It is too much voltage, the must load 14.5 volts .. First of all you check the fuses and the mass cables, you can also discourage the filter sensor and check the oil level according to the house. These cars should go with the oil a little on level because they have a sensor in the engine of the engine.
15 years 2 months before #12508 by manual-mecanica
I agree with short circuit, this is the high high load. I think the voltage regulator fails, you have to review it.
greetingsB)
