Bronco Differential 69
15 years 3 months before #12441 by manual-mecanica
Bronco Differential 69 Published by Manual-Mecanica
Hello friends I have a Ford Bronco from 69 and I would like to change front and rear differential for one that has disc brakes that vehicle I can adapt the whole system thanks I hope your help
15 years 3 months before #12478 by manual-mecanica
Manual-Mecanica response on the re: Bronco Differential 69
Do not entertain or change by disc the braking will not be good and you will have many problems, and if you still want to do it, try to only modify the brake system and make the adaptation of the discs
