problem with change box of an astra
15 years 3 months before #12448 by manual-mecanica
Problem with change box of an astra published by Manual-Mecanica
Hello, I tell you that I have a problem with a chevrolet astra 1.8 year 2000.When step march, it costs the first one, I have k forsenjer for k dentre. If it is a problem box or varillage. Any response is appreciated.
15 years 3 months before #12481 by manual-mecanica
Manual-Mecanica Answer on the Rera change box problem
I don't think it is a blacker since the system of that vehicle is because of a plastic apparatus now tells it is only the first march or the others too?
15 years 3 months before #12499 by manual-mecanica
Hello, yes in this case it is just the first march, I have to k force it for k dentre, with the engine stopped or running it is the same.
15 years 2 months before #12509 by manual-mecanica
Hello, I don't know if it will be the same problem but my daughter has a 1998 cupe
astra
15 years 2 months before #12575 by manual-mecanica
Look at the measures of the clutch pedal at the wheel of the direction, first measures with the steering wheel and then released and look at the difference, the difference has to be between 125 mm to 132mm with the stepping pedal and without stepping on the pedal
if the clutch screw does not tense the clutch of the Embrager spot that you cosigate the measurements.
