Problems with a Fiat Punto 1.7 TD SX
15 years 3 months before #12458 by manual-mecanica
Problems with a Fiat Punto 1.7 TD SX published by Manual-Mecanica
Hello everyone. I have changed the Cuat Board to my Fiat of 97. And water continues to leave the exhaust tube and do not start, please someone if you know how to put the tuning that helps me. Cock the Board of Cuatura because oil and water from the escape came out. The new joint that I put is with a notch. That I do I am already desperate. Thank you beforehand.
15 years 3 months before #12494 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Fiat Punto 1.7 TD SX
You mediated compression and rectified the cylinder head or just changed the joint?, did you check that the butt is not crooked, or just changed the packaging and now.
15 years 2 months before #12529 by manual-mecanica
I have not measured the compression, but I took it again and this cracked. So that new butts anyway.
