XSARA PICASSO 2.0 GASOLINE COMPUTER
15 years 2 months before #12593 by manual-mecanica
XSARA PICASSO 2.0 GASOLINA PUBLISHED BY MANUAL-MECANICA
Hello, I would disarmed to know if my Picasso's computer can be reprogrammed and what is the process to do so. The problem is that the gasoline level indicator does not work well, the central block does not work from the key, the rear bath door is unlocking after half an hour of having blocked it, the external temperature indicator does not work either.
