Neon 95 problems does not turn on
15 years 2 months before #12696 by manual-mecanica
Neon 95 problems does not light published by Manual-Mecanica
Hello I have a 95 neon and it does not turn on it costs a lot to turn on but when I manage to turn on and the engine heats I can turn it off and light it without problems the problem is to tell the engine is cold .... thanks for your help .......
15 years 2 months before #12702 by manual-mecanica
Manual-Mecanica response on the Re: Neon 95 problems does not turn on
In these cases it is best to check the temperature sensor, it is the main culprit, Checalo and let us know is not an expensive feet if you have to renloitate them.
15 years 2 months before #12705 by manual-mecanica
Hello,
the first thing to check would be:
- Temp sensor
- Fuel pump pressure
- Fuel corrections (Settings)
The latter you can check when the vehicle this cold tries to turn on, then disconnect the battery or if you have access to a scanner dale "reset adaptive Values". Then turn on if it is not launched, verify how many degrees of TEMPLA, if the time was the ignition, it would not weed much, on the contrary when the engine would heat the failure would be lost of power due to excess fuel, this since the principle of operation of these sensors of NTC negative thermal coefficient.
luckB)
