Water oil step in Renault Express 1.4 1996
15 years 3 months before #12770 by manual-mecanica
Water oil step in Renault Express 1.4 1996 published by Manual-Mecanica
I have problems of water to the water I did a hydraulic test to the cylinder head and this good I need help or who has the repair manual of the Furgon Renault Express 1.4 Bencher 1996
Atte.
Araya Rodriguez
15 years 3 months before #12878 by manual-mecanica
The first thing is to check the distribution lid that is not starry and then make the oil veins in the head, I in the monoblock,
15 years 3 months before #13024 by manual-mecanica
    It can also be due to fractures of packing
15 years 3 months before #13051 by manual-mecanica
I think that the first thing you should check is whether there is a heat exchanger between oil and water, then Penzar in the lid joint, strange can be a crack in the butt or block
15 years 3 months before #13077 by manual-mecanica
I think just like Davalos, first check the oil refrigerator (if you have it), then I continued with something else.
