My car goes out
15 years 2 months before #12904 by manual-mecanica
Manual-Mecanica response on the Re: my car goes out
Betop friend Saves because of what you tell me I think that you could have a current problem in your car, you have an easy and let me know how it went, what am I going to tell you happened to Kia Abella and nobody gives with the problem, put the car in Relay until it is kept alone, you see this turns on all the lights radio air conditioning and everything, give it all the consumption that you can and tread the brake Or go down the revolutions notoriously almost to the point of turning off your problem is the vehicle's land, after this test repeats but only stepping on the brake, nothing more caught, if it stops again, take out the brake fuse and if I do not stop or anything weird, it is earth definitely, you have this and let me know, then I tell you what else to do
14 years 11 months before #14977 by manual-mecanica
Hi,
the same thing happens to me, they connected to my Ford Ikon 2003, a fountain with a bending boofer departure, the next day when they went to work, the velimeter stops working and in the afternoon when brake and stops revolutionizing the engine goes out, will it be that they did not connect any device? Or it is making false land, I read in a forum that probably damaged the velocimeter sensor.
That they recommend me, I carry it with an electric or Qito the team that mount.
Thanks for your comments.
14 years 11 months before #14986 by manual-mecanica
Try by taking the equium and try if everything has been well in the inatalization of new lands, do not hang from those that are already remembered that the consputers feeds on pure lands.
14 years 11 months before #14992 by manual-mecanica
I already did, it doesn't remain that it could be?
14 years 11 months before #15009 by manual-mecanica
Check how much your alternator marks with everything on if the problem is very little there
