Ford Focus
15 years 2 months before #13159 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Focus
How the Zetec 2.0 engine is generally very good, the problem with this car would be transmission, automatic is delicate.
But out of that, the little machine is very efficient, very good consumption/performance vs. power.
15 years 2 months before #13162 by manual-mecanica
Well, the truth, it depends on the state in which this since they want to sell it but does not bring much mileage separate is a very beautiful road car :)
15 years 2 months before #13173 by manual-mecanica
Zetec engine gasoline consumption is a little high since it has 16 valves 30 kms by gallon is like saying competition is very fast, there are other focus that have the Split 2.0 cc engine the same one that uses the Ford Escort and this only have 8 valves and they make you average 37 km per gallon with activated air and it is very veil also, with the relationship of the automatic boxes, they are very veil, with the relationship of the automatic boxes. The work in the Ford lines, what is always recommended is to check the oil level and change the same year.
Good luck ,,,,,, Verify what motor you want to have your focus if a high consumption or low gas consumption engine ..
greetings from Honduras C, A
