Back problems
15 years 3 months before #13028 by manual-mecanica
BACHES PROBLEMS PUBLISHED BY MANUAL-MANICA
Hello everyone and thanks in advance. I have an Audi A3 with a problem that is already serious. When I take a pothole, hole, Baden, sewer, the car passes my front suspension quite well but the rear hits me a great blow, it does as if I left the backward wheel with the bump and the car is destabilized. When the car rains when it limps a white stripe skates me by giving me a whip and then grabbing again. The wheels are new and the Silentblocks are new too. I have done it with Michelin, Yokohama and Bridgentone wheels, so the pneumatic ones discard them. Greetings and forgive for Toston.
15 years 3 months before #13036 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Baches
Los Checaste traceros shock absorbers, so you say is a traction problem and it can be because the shock absorber does not keep you attached to the floor
15 years 3 months before #13043 by manual-mecanica
Today I have been in the workshop and I have checked the rear bridge, Silenblocks, rotula etc. And they have told me that they can be the rear shock absorbers. We will have to try new ones to see if it is stable. thank you so much !!!!
15 years 3 months before #13057 by manual-mecanica
Good, check the rear alignment of that vehicle, since wear 2 2 bars per side to align the rear suspension, also check that these bars are not folded
15 years 3 months before #13065 by manual-mecanica
That axis cannot be adjusted since it is complete and not adjustable, and according to the parameters of the car is not folded. Thank you very much.
