petrol pump
15 years 2 months before #13239 by manual-mecanica
gasoline pump published by Manual-Mecanica
Hello my problem is that my car does not turn on but the sound of the gasoline pump is not heard and I cannot locate the pump relay since the fuse box has no lid. And I don't have the car manual. It is a 1992 Ford Ghia. V6. thank you.
15 years 2 months before #13248 by manual-mecanica
Manual-Mecanica response on the Re: gasoline pump
Locate the unplugging pump and with a trial in 12V continuous current or a 12 V lamp, set out if you reside, otherwise the pump does not work.
2. On the side of the one driving below the door side in some cars there is a shock switch could be activated.
3 There is no need for a manual for relay with a bridge is enough to be able to locate it with a stretch of cable and two pins you take out an X relay relay and you are causing until you find the pump
The relay is an electrical switch when activating an electromagnetism that causes a bridge to withstand the electrical consumption of the pump from the contrary, it would be burned any burial of minor amperage ...
