Daihatsu Charade 92 - Carburation
15 years 2 months before #13240 by manual-mecanica
Daihatsu Charade 92 - Carbation published by Manual -Mecanica
I would like you to help me solve a problem that I have in the carburetor of my Daihatsu Charade 1992 Model G100LS-GMDS (gas station), since I have changed the chicler of high and low carburetor and I have problems with the exit (jump and speed is not constant) and is consuming me too much fuel (gasoline 90 oct.) 30xgl. The high chicler is 110 and the one with Low 74, I would like to help me solve this problem informing me about the chicler that correspond to my car and also answer me if the current and/or the distributor has something to do with consumption or in the advance of the vehicle. Ok. THANK YOU SO MUCH.
15 years 2 months before #13244 by manual-mecanica
Manual -Mecanica Response on the Re: Daihatsu Charade 92 - Carburation
Hello, how are you ... well, I throw you a couple of solutions that could help you
* The car does not regulate even ... take out the air or lid filter that covers the carburetor and does the following starts up and with a flashlight when the engine regulates looks towards the mouths or mouths of the carburetor would have to look clean if you look like fuel you have a problem of the floating constant.
The carburetor is a complex piece if it is not studied in detail.
