Fairy Witness
15 years 2 months before #13377 by manual-mecanica
Averia witness posted by Manual-Mecanica
Hello, I would like to know how I can take out a failure that gives me in the light box of an Opel Astra Enjoy of 2006 1.6 16V. In the workshop they tell me that it can be a mistake like a badly closed door and they can't get my fault. If you want I put the fault code that I get out of
15 years 2 months before #13403 by manual-mecanica
Manual-Mecanica Answer on the Re: A FAILURE WITNESS
Look at the only way to erase the codes is with a diagnostic team there is no other way, and so that you disappear you have to repair the fault if you do not always appear, however an aviert door does not throw any fault code, only the ABS injection system or airback do so so Check
