ELECTRICA SEAT CORDOBA FAILURE
15 years 1 month before #13520 by manual-mecanica
ELECTRICA SEAT CORDOBA FAILURE PUBLISHED BY MANUAL-MECANICA
Hello to all partners, I have a Seat Cordoba of 99, 1.4 Gasoline I first stopped working the trunk light, then the one of the registration, and finally the antinieblas ,, and I have already proven bulbs and fuses and they are not, to see if someone can help me because when I pass the ITV, they tell me that I have to fix them ... Thank you I hope answers ....
15 years 1 month before #13528 by manual-mecanica
Manual-Mecanica Answer on the Re: Electric Fair Seat Cordoba
It can be a problem of some relay or simply the telecoming that is failing to directly feed these Sircites see if they work, or check the telecomando signal, that is, it exits the systems.
14 years 7 months before #17167 by manual-mecanica
Hello, if the problem is not yet solved, I tell you what it can be of the cables that are broken, these cables pass through the pascasable tires that are to the right and left of the rear gate
greetings
